A friend of mine had his late 2 year old Transit Van (also used for towing his Mini's) with all his work tools stolen in London today, despite it being securely locked and immoblised like most other modern vehicles. Turns out Ford vans have a security weakness detailed below.......if you know anyone with one please warn them to take preventive action before it is too late........
"Thieves have discovered a new way to steal your Ford van via overriding the manufacturer’s immobilisation system by connecting a Laptop/PDA into the OBD socket and programming a new key into the ECU.
They start by decoding the manufacturer’s door lock which unlocks all the doors, disables the alarm and gives them the key combination for your van so they can get a key cut with a new chip.
Once the key is cut they return to the van, unlock the doors with the new key and then connect their Laptop/PDA into the OBD/ECU connection where they can program in the new key, start the vehicle and drive it away — All without causing any damage."
Our Patented OBD/ECU Connection Protection Device encompasses the plug in a Secure Box which is attached to the anti roll bar behind the dashboard and can only be unlocked with the correct code/key.
Supplied and Fitted for £95 - Prevents Ford Transit Theft
As WE Designed, Developed & Manufacture this product we can make necessary brackets for any vehicle. Please call us on 01375 891 646 for more information.
http://www.protectavan.co.uk/content/ec ... ion-device
Transit Forum - loads of thefts have been reported here on late Ford Transit vans :
http://fordtransit.org/forum/viewtopic. ... 4&t=112409
Stolen Ford Vans Alert
- woodypup59
- Been thanked: 13 times
Re: Stolen Ford Vans Alert
I beleive this is a problem across a wide range of modern cars, in particular, higher spec models with key-less ignition.
Keyless means the pikeys don't even have to get a key cut.
