Exhaust manifold temps.
Posted: Mon Oct 18, 2010 11:50 am
by Gray
As the title says, what sort of temperature would an exhaust manifold be running at under normal conditions??
I'm thinking of getting mine ceramic coated but would not want it burning off at the price it costs, there seems 2 styles one at 900 degree temp and one at 1000 degrees.
Re: Exhaust manifold temps.
Posted: Mon Oct 18, 2010 7:43 pm
by littler
well when you give my car a good run on the dyno the center primary gets to about 650 deg c - is a dullish red.
when getting manifolds ceramic coated many people have the outside done, but its the inside you really need to have done . im not to sure but i think it is probubly down to cost as the outside is much easyer.
we had it done on an aston manifold after the one that was wraped in glass roll burnt away!! (over a period of a few years of constant dyno work) we went to re-wrap it as the blowing was getting a bit over the top , we found there was no 6 into 1 colector left practicly!,
you need to also make sure it doesnt get dented as it will flake off inside the manifold.
Posted: Mon Oct 18, 2010 9:01 pm
by Gray
Cheers for that, Yep I was going to get it done inside and out. http://www.camcoat.com/main/thermal-barriers-2
Posted: Tue Oct 19, 2010 7:05 pm
by littler
there allrite, we had a pain in the arse customer get his mechanicle fuel injection V8 manifolds done by them.
