1071 INLET MANIFOLD
Posted: Thu Apr 10, 2014 5:28 pm
by BRI MK1
Hi I have an inlet manifold part number AEG 179 is this correct for the 1071 cheers Brian.
Re: 1071 INLET MANIFOLD
Posted: Thu Apr 10, 2014 5:36 pm
by Gareth Brandt
BRI MK1 wrote:Hi I have an inlet manifold part number AEG 179 is this correct for the 1071 cheers Brian.
Yepp
Posted: Thu Apr 10, 2014 5:44 pm
Yup, it isd.
The manifold is actually the same casting as the late 997 Cooper one, can't remember the number off hand. But this part number has been ground off & the new number stamped in by hand.
Posted: Thu Apr 10, 2014 5:52 pm
by BRI MK1
Thank you very much for quick reply cheers Brian.
Posted: Fri Apr 11, 2014 2:14 pm
by Toby
Brian, it would be the correct one for a 1071 without closed circuit breathing. As Mark said its an adapted version of the 12A309:
If it would have closed circuit breathing you would need a AEG347 manifold, as this has the take off for the PCV:
If the 179 manifold is undamaged, would you be willing to let it go?
The pictures are courtesy of Ricardo
