Mk1 Mini Door Latches
mk1mini72
Post by mk1mini72 »
Hi everyone, was scrolling through Ebay the other day and came across these internal door locks, but the one you can lock from the inside has a larger latch. In the advert it stated that they were for a 1959 car! Could anyone tell me whether this is true, as i have a pair sat in the Garage...
steve1071
Re: Mk1 Mini Door Latches
Post by steve1071 »
Tim
Post by Tim »
And you can tell they were from an Austin, because they are black, whereas the Morris ones were body coloured.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
nickacb
Post by nickacb »
I guess not necessarily 59's, I mean those kind of rounded locks were also fitted to 1960 minis, or at least thru half that year
nick rogers
Post by nick rogers »
And if you turn them over you will find the date stamped into the metal.
mgb
Post by mgb »
Interesting comment about the colour of the latches, the ones on my '65 built Morris S are black, did they drop the body colour or have mine been replaced in the past?
Pete
Has thanked: 15 times
Been thanked: 37 times
Post by Pete »
No, all Coopers had black painted latch casings, probably all Longbridge built Minis?
minitravellerman
Post by minitravellerman »
My '64 Morris Traveller had black locks when I got it originally. I'm pretty sure they were the original ones as the whole car was original and unmolested. Cowley built car as well.
Ian Campbell
java gt
Post by java gt »
My late 60 CKD Irish Seven has these and I know of early an early 61 Irish Seven with these locks as well.Probably using up stock.
MiniMark1
Post by MiniMark1 »
I once had a very original one owner - 1961 Austin Mk1 in Speedwell Blue. That had colour coded door mechanisms. :shock:
Smashing car - took it to Monte Carlo on the French inter-rail service for the Grand Prix and then followed some rally notes that Paul Easter gave me up over the Alps.
Definitely one I regret selling!
