Speedwell Cylinder Head Identification
Posted: Sun Jun 27, 2010 6:44 am
by mini129
How do I identify which model speedwell cylinder head I have.
It had C 317 D stamped in above the hole for the temperature sender.
Re: Speedwell Cylinder Head Identification
Posted: Sun Jun 27, 2010 12:19 pm
by ricardo
It's a Clubman (C) head.
Posted: Sun Jun 27, 2010 10:48 pm
by mini129
Thanks. I found the speedwell cylinder head section on the site after I posted the question.
Does the 'D' after the number mean anything?
The head came with the 1.5 speedwell rockers but no valve springs.
What would be a good set of springs to use other than the obvious speedwell ones?
Posted: Mon Jun 28, 2010 8:12 am
by almondgreen
I have a set of NOS Speedwell springs here.... (VA50.BMC)
Posted: Mon Jun 28, 2010 8:45 am
The "D" after the head number is a batch. I have seen A through to F on various heads.
Posted: Mon Jun 28, 2010 10:42 am
by mini129
Thanks Is there anything speedwell you don't have a stock of almondgreen?I will contact you.
Thanks mark on identifying the 'd'. I will contact you also on the issue of valve guides.
Posted: Mon Jun 28, 2010 11:27 am
I reccon that between us Andreas (Almondgreen) & I more or less have a complete Speedwell franchise
