How do I uplaod photos from Photobucket
Hi, would somebody please advise how to upload soem pictures from Photobucket to the Mk 1 site please? As I recall it was something to do with IMG codes but I havent got any idea how to do this successfully. Cheer. Mark
- mab01uk
- Has thanked: 99 times
- Been thanked: 73 times
Re: How do I uplaod photos from Photobucket
Go to your Photobucket library select the photo required then click on it and the IMG code should appear in the list on the RH side of photobucket page......click on the IMG link code, it should say copied, then right click on your Mk1 Forum message area and select paste, the IMG code should appear and when you preview your message your photo should appear ready to finally submit.
If the IMG codes does not appear you will need to go into you album settings. There is a drop down menu next to your user name, click on User Settings, then on the albums tab. Once the albums tab has been opened there are various check boxes which you can tick which allow different types of linking. If you click the IMG one, then click on the Easy Linking Mode, which is further down the page, then the IMG codes will appear below the thumbnails in your album. To copy these left click the code so it is highlighted, then right click on the highlighted code, left click on copy, then you can right click on your post in the forum and left click paste. The IMG code should then be copied into the post.
Hope this helps
Stuart
Hope this helps
Stuart
