Recently picked these up, when was the production cut off for these?
Thanks Scott
Plastic kick plates
Re: Plastic kick plates
Someone has been selling repro ones on eBay recently. They look pretty good in the photos.
Tim
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
- mab01uk
- Has thanked: 99 times
- Been thanked: 73 times
Here is the ebay link:-
Classic Mini MK1 1959 to 1962 Morris door kick black plastic inserts LH and RH.
As originally fitted to 1959 to 1962 Morris Minis only. (Austin Minis had the aluminium plates but these will fit)
The original Morris part numbers are:-
ADA3733 Protector, door pocket, RH
ADA3734 Protector, door pocket LH
These protectors are reproductions reverse engineered from undamaged originals for a classic Morris rebuild. I had a few spares made and these are left over. They are slightly thicker plastic than the originals and are thus more resistant to kick damage. Also they are slightly ‘over sized’ around the edges to allow trimming to suit your particular door pocket mouldings that can vary a bit (items ADA3735 and ADA3736). Holes will need to be cut in the correct places for the door check strap screws.
See photo of a RH Protector fitted to my own rather battered 1960 Morris Mini.
http://www.ebay.co.uk/itm/Classic-MK1-M ... 7675.l2557
- mab01uk
Might be worth asking if he can have another batch made if the demand is there?min16i wrote:Bugger, missed that one.
