Engine and gearbox thread specification
L7MAD
Post by L7MAD »
Just cleaning up the threaded holes in my engine / gearbox unit and wanted to confirm / find the thread specifications for some of them:
Are the spark plug holes M14 1.25 ?
Is the temperature sender hole 5/8" UNF ?
What is the thread of the bypass hose pipe in the head ?
What is the thread of the oil pressure gauge feed hole ?
And finally what is the thread of the sump plug hole ?
Thanks very much
Paul.
Has thanked: 204 times
Been thanked: 76 times
Re: Engine and gearbox thread specification
L7MAD wrote:Just cleaning up the threaded holes in my engine / gearbox unit and wanted to confirm / find the thread specifications for some of them:
Are the spark plug holes M14 1.25 ? Yes
Is the temperature sender hole 5/8" UNF ? Yes
What is the thread of the bypass hose pipe in the head ? 5/8" UNF
What is the thread of the oil pressure gauge feed hole ? 1/8" NPT
And finally what is the thread of the sump plug hole ? 5/8" UNC
Thanks very much
Paul.
Hope that's some help :)
rich@minispares.com
Post by rich@minispares.com »
the thread in the cylinder head is 5/8 th UNS not UNF
rich@minispares.com wrote:the thread in the cylinder head is 5/8 th UNS not UNF
So, the same as the crankshaft threads?
Smiffy
Post by Smiffy »
Yes it's the same as the crankshaft thread, which is WF and not UNS. It's in the manuals.
Smiffy wrote:Yes it's the same as the crankshaft thread, which is WF and not UNS. It's in the manuals.
Smiffy, you are correct. That was passed on to me a few weeks ago and upon checking, they are not UNS. A college did say a few years back that he tracked it down as a British Small Arms Thread, but I've not (yet) been able to find a table on them.
Smiffy
Post by Smiffy »
It's a Whitworth Form Thread not the same as BSF.
Smiffy wrote:It's a Whitworth Form Thread not the same as BSF.
No, it's not BSF, that's right, but (and I know what the W/S Manual says) it's not whit either. Whit has a 55 degree included angle yet the thread on the flywheel bolts are 60 degrees. It maybe a British Small Arms thread or it could be 16-UN Thread type, but definitely not British Standard Fine.
L7MAD
Post by L7MAD »
Thanks guys, I knew this would be the correct place to ask!
What manual are you referring to? As I looked in the mechanical parts book and the BMC workshop manual but could not see anything, is there another one?
I assume the thread in the head you are referring to in the last posts is the bypass pipe thread and not the temperature sender one?
Also is there a close match parallel thread to 1/8" NPT that I could re tap the oil pressure hole to fit a banjo bolt/fitting?
Thank again.
Paul.
rich@minispares.com
the temp sender one is 5/8 unf, same as the servo fitting
This is from the factory manual AKD 4935
As you can see, it's only a mention of the crank thread (which is the same both ends by the way!).
The Oil Sender Thread is tapered for a reason ;) I wouldn't recommend changing it to anything else. The correct tap should be easy to come by and not at all dear.
Maybe a correction - somewhere - is in order? :D
https://www.minispares.com/product/Clas ... o%20search
I seem to recall that's where I originally found that info and that's what i have been fitting.
