wheel studs
Posted: Fri Nov 22, 2013 7:34 pm
by slowboy
please can anyone advise, what is a good coarse thread stud upgrade that uses nuts with the correct angle on the taper, is anything easily available ? thankyou
Re: wheel studs
Posted: Fri Nov 22, 2013 8:23 pm
by InimiaD
Swiftune do some really nice replacement studs. Not cheap, but they are the dogs.
Re: wheel studs
Posted: Sat Nov 23, 2013 9:25 am
by rich@minispares.com
slowboy wrote:please can anyone advise, what is a good coarse thread stud upgrade that uses nuts with the correct angle on the taper, is anything easily available ? thankyou
ive never seen mini studs available with anything but the normal 3/8th unf thread
I suppose you could look at using later rover metro 100 as they used a coarser metric thread
Re: wheel studs
Posted: Sat Nov 23, 2013 11:26 am
by Vegard
I've been thinking several times about redrilling the hubs, fitting 12mm bolts. It would be great as the 3/8UNF ones are a bit weak. I now use a torque wrench EVERY time when fitting nuts, never a problem anymore.
Re: wheel studs
Posted: Sat Nov 23, 2013 6:38 pm
by slowboy
thanks guys, am wanting coarse thread for longevity and quicker on and off , will see what swifty has
Re: wheel studs
Posted: Sun Nov 24, 2013 8:09 am
by GraemeC
Quicker on/off - just treat yourself to a decent cordless impact driver
Re: wheel studs
Posted: Mon Nov 25, 2013 8:07 am
by sandman
Be adviced that's Swiftys studs are only suitable for open-end nuts as used with Rosepetals or as the stock nut from waay back...
Re: wheel studs
Posted: Mon Nov 25, 2013 10:42 am
by Vegard
sandman wrote:Be adviced that's Swiftys studs are only suitable for open-end nuts as used with Rosepetals or as the stock nut from waay back...
I'd say that depends hugely on which wheels you are using. Genuine Minilites are no problem as the face of the wheel is very thick, but you've got a point.
