Can you identify this engine block?
Fass
Post by Fass »
Good evening. I found this block 10 meters a way from my Downton car in the same garage. The owner doesn't remembre anything about this block....can any one identify if its wrote saving it? Maybe its only an Authi Mini 850 engine and it can sit there forever, haha....
I also found a set of 4 brand new titanium rods...I'll take a pic of them!
Craig
Re: Can you identify this engine block?
Post by Craig »
Looks like a 1275 pre A+ block , GT or austin 1300
Craig
ricardo
Post by ricardo »
Late thick flange 1300 block (casting 12G1279). A series rods. If it is 11 studed possibly has a tutrified crank (12G1505 ground off and 1817 stamped).
251 ENG
Post by 251 ENG »
The 1968 CCC / Downton racers used 1300 blocks not cooper s blocks :geek:
Pete
Has thanked: 15 times
Been thanked: 37 times
Post by Pete »
Some of 'em did :geek: :geek:
:lol:
Fass
Post by Fass »
Thank you, but I don't understand what do you mean. Where can I find those codes stamped?
Regards,
ricardo
Post by ricardo »
Block casting number on the back, bottom right:
Crank number on the crank web:
Simon776
Post by Simon776 »
From the rather poor quality photograph it is hard to tell but the engine number tag looks Spanish so it is probably an NMQ (rather than Mowog) 1275 block.
If that it the case, it will have a different casting number, 12G1283 or something like that.
davidnutland
Post by davidnutland »
251 ENG wrote:The 1968 CCC / Downton racers used 1300 blocks not cooper s blocks :geek:
Some may have but I have a Ex works CCC Downton engine with thick flange S block, it came straight from the horses mouth!
david
Has thanked: 59 times
Been thanked: 15 times
Fass, all the above answers are wrong mate, sorry. The engine is junk, I'll happily take it away for you :D
