1071 Speedo question
SteveG
Post by SteveG »
My 1071 speedo is missing the top middle plastic bulb. I'm not sure what colour it should be.
Parnel's book is inconclusive. Can someone help?
nick rogers
Re: 1071 Speedo question
Post by nick rogers »
The lens is in fact red but there should be a rubber cover over the mount where a bulb holder would be. I have many mk1 speedos but can't recall any having a bulb at the top.
ditto.
SteveG
Post by SteveG »
Thanks.
I meant the lens. I found a photo of one via google which had a green lens ?
Red sounds right to me.
Gareth Brandt
Post by Gareth Brandt »
Green lens later speedo......
ianh1968
Post by ianh1968 »
All the 'S' types I have seen have NO lamp at the top, ie the 70mph position...
The 90mph types had a green lamp at the top, 50mph position.
Left side top, Yellow, Spare/Oil Filter
Left side bottom, Blue, High Beam
Right side top, Yellow, Oil Pressure
Right side bottom, Red, Ignition/Dynamo/Alternator Charging
Top (Optional), Green, Indicators
Out of interest, I usually wire BOTH the yellows to the oil pressure switch,
to provide a "spare" in case a bulb goes. The second one used to be connected
to the oil filter pressure differential switch and was supposed to indicate when the
filter was clogged.
If you only change the filter when prompted by a lamp, shame on you! :oops:
KA2S4
Post by KA2S4 »
I have an early-ish (black face) 90mph one with a black dummy lens at the top.
It's black and light won't shine through it at all.
J
Gareth Brandt
Same in my early 1275 s.
I've the same on my 120 (dead) speedo.
SteveG
Post by SteveG »
Hi Andrew
So you have a red lens at top also?
When did the speedos change to having no lens at top?
KA2S4
Post by KA2S4 »
Black Steve,
The lens is black.
It looks like a lens but it's a plug.
J
KA2S4 wrote:Black Steve,
The lens is black.
J
That's right James, mines just like yours :shock:
SteveG wrote:Hi Andrew
Steve, it's a black lens like James's
Not sure when the lens was deleted. Anyone ?
ricardo
Post by ricardo »
September 64
SteveG
Post by SteveG »
So a couple say red and a couple say black.
Could it just be a random BMC thing or ?
Gareth Brandt
SteveG wrote:So a couple say red and a couple say black.
Both my April 64 ones are black
Having checked, I have a red one that is blanked off & a black one. Both are early 1071 clocks.
SteveG
Post by SteveG »
OK, thanks for the input.
