Mk2 gauge in mk1 car
petrolhead
Post by petrolhead »
Temp gauge is bust
Can get a new mk2 one however the bezel is different, Can I just swap my mk1 onto the mk2 gauge
Will I need to fit a voltage regulator
Smiffy
Re: Mk2 gauge in mk1 car
Post by Smiffy »
It's easy to swap the bezels, if you look at the back of the chrome rim you'll see the tags that need folding back then just twist it off. You'll need a voltage reg for a more modern gauge, as they dropped the voltage to improve accuracy. Not that you can call any mini gauge accurate :lol: :lol:
petrolhead
Something else I have thought off, the sender in the head, will that need changing as well?
Smiffy
Post by Smiffy »
I believe the early ones are different, so yes I expect you do need a suitable sender.
ricardo
Post by ricardo »
Going by the size of the blue/cold mark, this should be pre voltage stabilizer version.
If you decide to buy it, ask a picture from the back first to confirm it is what you need. What year/month is your car?
http://www.ebay.co.uk/itm/SMITHS-CLASSI ... 3cd47d66e9
