Rear camber toe kits
Posted: Sat Jul 06, 2013 3:22 am
Started to install the Mini Spares rear toe and camber today. On the right side, the mounting holes did line up, had to file some the holes for fit. Right side took less fitting. There were plug welds inside the mounting brackets, that I ground flat, so the thrust washers would have more area on the trailing arms. I did install new bearings and bushings in the rear trailing arms. Just looking at one arm on, it appears the kit is designed for negative camber and toe out? My plan is too adjust for, 1/16 inch of toe in (is this per side or total toe?). Camber, would adjust to about, +1/8 degree to +1/4 degree. Once the car is on an alignment rack will try to adjust the rear for zero thrust angle. Anyone with experience on the these camber toe kits? The car will be a street driver not a race car. I will also be installing the Mini Spares caster camber kit in the front. Will that kit allow positive camber? Or do I need to cut the arm shorter? Thanks for the information in advance. Mr.lotus
