Hydrolastic displacers
Posted: Wed Sep 22, 2010 10:49 am
by abri
I changed my '65 from hydro to dry a while back & am starting to think it might have been a mistake. The mechanic didn't give me the original parts back that he removed. My question to you is, given the variety that exists in hydrolastic displacers, are they interchangable between standard saloons across the models that came with hydro? In other words are 65, 66, 67 displacers exactly the same if they came off a bog standard Austin Mini? Or are they dated?
Re: Hydrolastic displacers
Posted: Wed Sep 22, 2010 11:45 am
by madaboutcherry
apart from S displacers, all others are interchangable between models as well as front to back.
Posted: Wed Sep 22, 2010 4:14 pm
There were however various different versions over the years, different valving and spring rates, as well as a variety of different conditions.
Mixing & matching is never straight forward with hydro. It can be done, but usually takes more than a little buggering about to get right. This is why you see so many hydro cars either nose or tail up, or wonky in some other way. Mixing & matching displacers IS NEVER straightforward.
Posted: Wed Sep 22, 2010 5:05 pm
by abri
Thanks guys.
Mark, so in theory if you get all displacers from the same donor car and install them in a different one it should be fine?
Posted: Wed Sep 22, 2010 5:10 pm
That is indeed the ideal way of doing it. It saves a heck of a lot of heartache in the long run.
