Rubber strap round electronic fuel pump
- Has thanked: 7 times
- Been thanked: 6 times
Tried the Minispares variety and they fall to bits. Does anybody have any suggestions where I can get the rubber/foam strap that goes between the fuel pump bracket and the fuel pump (wraps around it). Cheers. Mark
Re: Rubber strap round electronic fuel pump
Why do you not buy minispares rubber/foam strap?
- Been thanked: 5 times
I have found that a BMC air cleaner to carb body rubber seal to be a perfect fit for both the petrol pump and clamp. It has a stepped lip on one side so the pump cannot slide out of place.
I think it is off an A40 or similar. Being original BMC rubber it will not disintegrate within 3 months like Chinese rubber seems to do !
I'll see if I can find my spare one and up a photo of it.
Thanks Andrew. Sounds like a plan.
Charlynsane- thanks for your reply but as per my text the Minispares variety I bought had a very short life span.
I use high density foam that is sold as draught excluder by the likes of B&Q.
Particularly good as it's self adhesive on one side too.
- Has thanked: 125 times
- Been thanked: 34 times
I have used rubber self-amalgamating tape with good success, it will last a very long time, but being rubber, it won't like oil or sunlight, however - thankfully - the inside of the rear subframe doesn't see much of either.
Mark,
Found a couple of new seals in the garage, one in its original BMC box !
Slipped one over a pump so you can see that it is a nice snug fit. The clamp also fits very well around it.
Found a pretty good original piece of foam as well, split in half but well useable if you want originality
Andrew
Andrew
I find a nice piece of inner tube works fine....
Unless, I suppose, one runs over the local originality police....
Cheers, Ian
Cheers, Ian
