Removing the bush from the intermediary housing
Posted: Mon Apr 22, 2013 11:35 pm
by rolesyboy
Would anybody have any good suggestions or tips on removing the idler gear bush from the intermediary housing. I have done it in the past using a dremel, heat, slide hammer, long nosed pliers, mole grips, youtube, a team of 3 people and an extraordinary amount of time.
There must be a better way
Thanks. Mark
Re: Removing the bush from the intermediary housing
Posted: Tue Apr 23, 2013 12:31 am
by LDR209H
If you're talking about the outer bearing race in the transfer case,that's not a DIY job in my experience (unless you have an oxy-acetylene torch and bearing puller to hand).
I've always shipped it out to local friendly old school engineering workshop man and furnished him with beer tokens.
Every job on a Mini is luvverly though ....
Posted: Tue Apr 23, 2013 1:59 am
I've seen people heat the housing and bang them down and other 'butchery' methods. Then they wonder why their idler gears scream and they get poor life from idler gear bearings
This is one job for which you should use the right tool. I have a Sykes Internal Bearing Collet, it goes in and then your wind it to expand it, it grips from behind the bearing. They suggest a slide hammer attached to then extract the bearing, but I have made a threaded puller, no banging. The Sykes tool is not at all expensive.
Posted: Tue Apr 23, 2013 9:07 am
by guru_1071
I have the proper puller for this (lar-di-da
but you can get it out with heat, but you have to warm the whole case in an oven for about half an hour, then drop it flat onto a large bit of wood, the bearing will just drop out, it your quick enough you can turn the case over and slide the new bearing in at the same time.
you can also get both the bearings out by mig welding a long bolt to them, the localised heat makes the case expand just enough for the bearing to pop out, but its a bit of a hit and miss method as its easy to melt the case
Posted: Tue Apr 23, 2013 10:16 am
by nick@dunsdale
would it hydraulic out ?
Done it many times on bearing's on gearbox end of a crank shaft, sweet little trick
Not sure if it would work on a mini transfer case, would be my first port of call though.
Posted: Tue Apr 23, 2013 10:41 am
by guru_1071
nick@dunsdale wrote:would it hydraulic out ?
this does sometimes work, but ive seen people try it and neatly punch the alloy case out on the other side.....
Posted: Tue Apr 23, 2013 10:58 am
by LDR209H
You're talking about one of these suckers ?
http://www.toolgurus.co.uk/sykes-pickav ... /?09581200
Then you'd need to fabricate the puller bit (ooer).
Posted: Tue Apr 23, 2013 10:59 am
by rolesyboy
Oooh lar di dah Rich. I will try the oven trick first as thankfully I already have one of them. If it melts the case I will buy a proper puller (and a new case!)
If you have a picture or name of the appropriate tool that would be great.
Posted: Tue Apr 23, 2013 11:21 am
by NZmember
Posted: Tue Apr 23, 2013 11:22 am
by nick@dunsdale
guru_1071 wrote:nick@dunsdale wrote:would it hydraulic out ?
Lol i would use an old transfer gear to hopefully avoid that happening
Posted: Tue Apr 23, 2013 10:55 pm
by Lord Croker
Wouldn't mind a quid for every time I've tried that.
I've never had it work yet & always resort to
the Dremel or similar.
When I worked for a Leyland dealer in the early 1970's we had all the special tools to remove the idler gear & 1st motion shaft support bearing outer, in a matter of seconds. Unfortunately when the place closed down, someone had already liberated them, along with the Cooper engined Mini pick-up.
Posted: Wed Apr 24, 2013 9:55 am
by guru_1071
Lord Croker wrote:
Wouldn't mind a quid for every time I've tried that. :.
why would a 'gearbox specalist' release a video like that....
you would think he had the correct tools for the job...
Posted: Wed Apr 24, 2013 9:46 pm
YES
But I only bought 2 of them as that's all that's needed.
Errrr,,, not something I'd recommend, but I have sold a few transfer cases to guys who have followed this.
Posted: Wed Apr 24, 2013 11:40 pm
by Lord Croker
With the correct puller, there is no need to warm the casing.
Posted: Thu Apr 25, 2013 7:16 am
You'd think he'd have a better blow torch that didn't blow out!
Posted: Thu Apr 25, 2013 8:54 am
by Vegard
I was thinking the same.. But then again, he only guesses that it works...
I've got the proper pullers as well. Mandatory.
Posted: Thu Apr 25, 2013 6:14 pm
by Lord Croker
I can't fault the logic in what you say, but I've never had any aluminium come out with the bearing in over 40 years, there was never any mention of heating the cases in either garage where I worked, where they had the correct pullers. Maybe I was just lucky!
Posted: Thu Apr 25, 2013 7:01 pm
by guru_1071
my top tip for stripping old gearboxes is to strip the diff off them, de stud them, undo the two big nuts, take the laygear out, then put them in a bucket of red hot water for half an hour, have a cup of tea, then whip the box out the water and get the two big bearings out whilst the case is nice and hot.
the mainshafts are often easier to strip with a bit of latent heat in them, particularly if the top hat bush is tight
the water does no harm once its stripped, I just spray a bit of wd40 of the gears once they are stripped.
I often will put the bare clean case in red hot water for a bit before I build them as well, just to help the bearings slip back in.
I just don't think its good practice to be thumping away with a punch and a lump hammer if the bearings are tight.
Posted: Fri Apr 26, 2013 1:52 am
by Lord Croker
I think I may have been labouring under some kind of misapprehension, I was referring to the bearings in the transfer housing, not the main gearbox. However, I would never apply the force of a lump hammer to remove a bearing from a light alloy casting & have never had the need to, even when cold. The big problem I find now is the tightening of the 2 big nuts with an impact wrench, I recently had to strip a Metro Turbo box because tightening the pinion nut in this way had taken teeth off the laygear. (The nut had to be ground off)
