Remove oil pressure relief valve SEAT
- Has thanked: 19 times
- Been thanked: 9 times
Any tips on how to remove oil pressure relief valve SEAT from the blockplease? (Not the oil pressure shuttle/ball) Thanks. Mark
Re: Remove oil pressure relief valve SEAT
mark
if you hammer a peice of wooden dowel into it, it should grab it enough to withdraw it.
ive used this method a couple of times.
I drilled and tapped mine and pulled it out with a long bolt
- Has thanked: 206 times
- Been thanked: 79 times
Some I've come across already had a thread. These were engine untouched from the factory too.coop12g295 wrote:I drilled and tapped mine and pulled it out with a long bolt
Just be careful as they don't all come out easy and can do damage to the block which is difficult to fix.
Mine was tight and I'm amazed how much dirt was behind it,definetley well worth pulling out
Glad you said that. I was just beginning to think sahll I leave it in there.
The last thing in the block too. Shame on me for having such thoughts
