Plate under master cylinders on LHD cars
Posted: Fri Feb 08, 2013 9:39 am
by AndyB72
Re: Plate under master cylinders on LHD cars
Posted: Fri Feb 08, 2013 12:33 pm
by Vegard
You've got a plate for a twin circuit master.
Posted: Fri Feb 08, 2013 12:55 pm
by AndyB72
Thats what I was thinking, is the one for the baked bean can master cylinders different? Anybody got one for sale?
Posted: Fri Feb 08, 2013 1:36 pm
by JC T ONE
Vegard wrote:You've got a plate for a twin circuit master.
which Hydro car has twin circuit master ? some Inno model ?
The brake master cylender has a bigger foot, so isnt it a clutch master in the pic ?
Posted: Fri Feb 08, 2013 2:10 pm
by guru_1071
your correct, thats a small foot clutch master, the braker is bigger and has the little cut out in it.
andy must be getting confused as to what foot does what in a left hand drive car!
Posted: Fri Feb 08, 2013 2:33 pm
by AndyB72
I tried both master cylinders in and thought they were the same size, I just dropped in the first one I had to hand for the photo.
Posted: Fri Feb 08, 2013 2:46 pm
by guru_1071
ANDY
the NAM1718 is the spacer that corrects the length of the pushrod on the early tandam master cylinders
it was probably a quick bodge the factory did as they (i assume) found that as the brakes warmed up and expanded the fluid, the fluid would 'jack' the cylinder in the master cylinder up and jam the brakes on. sticking a fat shim under the master cylinder would increase the free stoke of the connecting pin and prevent this occurance from happening. using a shim would have been cheaper than remaking the length of the pin.
rich
Posted: Fri Feb 08, 2013 5:00 pm
by Vegard
JC T ONE wrote:Vegard wrote:You've got a plate for a twin circuit master.
A Norwegian 1275GT would for instance.
Posted: Fri Feb 08, 2013 6:02 pm
by JC T ONE
Hi Vegard,
just had a look in the BMC/BL parts catalouge, it say that BL did have a twinmaster (37H 2768) but that its not for the GT.
The only "early" GT I ever saw with a twinmaster cyl, was a Swedish 1974 (same spec as UK).
Hydro was deleted in 1971, so can you help with some details ? (for the 1275GT registre) .
Jens Christian
Posted: Fri Feb 08, 2013 9:15 pm
by AndyB72
A new one on me, I didn't realise brake masters came with different flange sizes. Looking at some old photos of my Inno before I restored it, it had the brake/clutch master cylinder with the smaller flange. A guy on another forum has confirmed his had a plate underneath the brake master cylinder.
Thanks for the reply Rich, I think I edited my post just before your reply. I did a google search and it came up that it was for the twin master.
Posted: Sat Feb 09, 2013 4:47 am
by JC T ONE
AndyB72 wrote:
Ahh - the big "foot" master cylender, in the flesh
