Hardy Spicer
Posted: Wed Feb 06, 2013 8:17 am
by JC T ONE
Hi all,
A friend asked me a question I could not answer, so I promised to post it inhere .
he has assembled his gearbox with a set of Hardy couplings, but when he tighten up the big center bolt, the collar on the Hardy flange goes in & touch the seal.
He has the correct sidecovers = no 22G420, and all bits shown on the parts picture is present, so what can be wrong ?
Re: Hardy Spicer
Posted: Wed Feb 06, 2013 5:50 pm
by carbon
Are the split collets all there and seating OK?
Re: Hardy Spicer
Posted: Wed Feb 06, 2013 6:16 pm
by JC T ONE
All parts according to the exploded pic on Mini Mania,s site are there.
I havent seen it, so I dont know the details, but you can be sure he checked all parts.
I will tell him about your question .
Re: Hardy Spicer
Posted: Wed Feb 06, 2013 7:21 pm
by minifreak71
carbon wrote:Are the split collets all there and seating OK?
All the collets are there, (2 in each side) and I believe i have assembled it correctly.
Re: Hardy Spicer
Posted: Wed Feb 06, 2013 8:17 pm
by guru_1071
as the large bolt is shouldered, and the large washer is a certain fatness, the bolt should allow the spicer flange to go to far into the diff to meet the seal.
it must be that either your bolt or washer are wrong, or possibly the spicer flange has had its end cleaned up (if it has got chewed up a little in the past from been run loose) and this allows it to go further home than it should.
must be an easy fix, what ever it is!
