non spacer type minifins or similar
814CWE
Post by 814CWE »
can u get minifins or similar which havent got the built in spacer"cooper s offset" ?????????
i want some for some front drum brakes..
aquamini
Re: non spacer type minifins or similar
Post by aquamini »
Hi i have some if you want them £30 thanks
814CWE
Post by 814CWE »
a
are they ok inside?
aquamini
Post by aquamini »
there are very few light grooves nothing drastic, they have never been skimmed so loads of life left in them though
814CWE
Post by 814CWE »
pm sent
814CWE
Post by 814CWE »
recieved -well pleased
thanks
ivor badger
Post by ivor badger »
To clear up the point. The original Minifins had no spacer and then they brought out Super minifins that had the spacer. Those who love setting their cars up exactly on lazer gear should be warned that quite often the wheel surface on the spacer is often not true to the hub surface.
aquamini
Post by aquamini »
Hi Brook glad you are happy with them
