Mk 1 indicator switch...
Posted: Tue Nov 27, 2012 12:46 pm
by sandman
Is this fixable in any way or just for the bin?
Apart from the broken handle - the switch is fine.... anyone that restore these?
Re: Mk 1 indicator switch...
Posted: Tue Nov 27, 2012 1:25 pm
by 814CWE
ive repaired these with epoxy resin and sanded them to a mirror smooth finish
a coat of black on the freshly repaired end,,good as new,,,,well,,good enough
Posted: Tue Nov 27, 2012 2:49 pm
by sandman
Is it possible to remove/ switch the stalk with another from a broken switch?
Posted: Tue Nov 27, 2012 3:03 pm
by 814CWE
sometimes yes sometimes no
Posted: Tue Nov 27, 2012 3:34 pm
by Frogeye61
I did that also, and I bought one of these:
http://www.ebay.co.uk/itm/MORRIS-MINOR- ... 2db&_uhb=1
I don't know if they are same as original or not, but I made the newly epoxyed lever fit that lense
Posted: Tue Nov 27, 2012 7:15 pm
by LDR209H
Yep,did the same. The end was 'epoxy-ed' in but you get at least 1 bulb's life out of it. These sort of repairs are quite satisfying when they go right,a whole lot more enjoyable than slapping on a modern repro anyhoo !
Posted: Sat Dec 01, 2012 12:30 am
by 62Countryman
Minimania.com sells a repair kit. Part # is Rep01
Posted: Tue Dec 04, 2012 8:35 pm
by sandman
Great - thanks!
