replacing water pump
- Vegard
Re: replacing water pump
You will probably require skin grafts on your hands/arms after doing the job, the thinner you are the easier it is, good luck
I have big hands. Ouch!
36inter wrote:You will probably require skin grafts on your hands/arms after doing the job, the thinner you are the easier it is, good luck
4 hours for me then!
Vegard wrote:Between 2 and 4 dependant on how much the radiator cowling hates you.
