Smiths impulse tach reading high
Posted: Thu Sep 02, 2010 1:08 am
by 65Austin
I have an RVI impulse tach that reads about 2000 too high, do I adjust this by moving the pulse lead "loop" at the head? or would making the leads longer before they attach to the coil work? or is it knackered?
just bought this used, and the pulse leads are about 24" long. how long should they be from new? the part where the lead loops through the tach appears to be untouched and perhaps in the original place?
thanks...
Re: Smiths impulse tach reading high
Posted: Thu Sep 02, 2010 1:55 am
by ivor badger
They always do, probably because they set them off the mains cycles. Look on the back and you will see a small flat rubber plug, remove it and you will see a white plastic screw head underneath with a screw driver slot in the top. This is the calibration adjuster. Iirc, the revs are correct at 3000rpm
You need to find a suitably calibrated tach to read the revs near full speed. Run the engine up to near max revs and turn the screw until the revs read correctly at the chosen speed. It's probably wrong at low revs, but that doesn't really matter.
Posted: Thu Sep 02, 2010 9:29 am
by mini129
Are you using electronic ignition?
Posted: Thu Sep 02, 2010 4:18 pm
As Ivor says, these tachos are notoriously badly calibrated and are more of a fashion statement than serious instrument to monitor your engine.
If you do want an accurate measure of your engine revs. my suggestion would be to buy a decent one.
Posted: Thu Sep 02, 2010 6:02 pm
by 65Austin
thanks for the info...
ivor - will give the adjustment a try
mini129 - regular ignition, MK1 998 cooper
mk1 - fashion statement, just need to find a good used pod for it
Posted: Fri Sep 03, 2010 2:29 pm
I probably came over a bit grumpy in my previous post. This wasn't deliberate, I use these old tachos. in a few of my Minis & am very happy with them. But when I need a tacho to be accurate I buy a new one.
Pods are available from the shop;
http://mk1-performance-conversions.co.uk/shop/
PS. I have about 10 left & this will be the last batch I do.
