best exhaust to use on a mk1 998 cooper?
Posted: Wed Oct 17, 2012 10:30 pm
by 814CWE
998 cooper mk1
,what exhaust manifold and system is good value for money ?
dont want a std pea shooter,but obviously too big a bore is a bit tight in the tunnel and dont want it clanking on the remote housing
wha tdo u guys use?
Re: best exhaust to use on a mk1 998 cooper?
Posted: Thu Oct 18, 2012 12:12 am
by Lord Croker
Although my Mini is not a Cooper, it is a 998 modified to give similar power, but without the twin SU's. I use a Sportex LCB manifold with an 1.75" outside diameter Maniflow single box system. The standard system was of that diameter so shouldn't cause you any clearance problems & there is no need to go bigger on an engine of that size. If you want it to look more original, a 1.75" RC40 side exit exhaust looks very much like the exhaust they had as standard. Avoid cheap LCB manifolds where the down pipe from no.4 exhaust port meets the down pipe from no.1 at 90 degrees, that does nothing for the smooth flow of the gases.
Posted: Thu Oct 18, 2012 10:23 am
RC40 every time.
Posted: Thu Oct 18, 2012 11:14 am
by 814CWE
i was thinking rc40,,,
theres so many types of manifolds,,,
i have the original 3 branch but its a horrid vile thing,,looks like one of an austin 1100 to me
Posted: Thu Oct 18, 2012 11:34 am
Personally I'd go for a maniflow 3 into 1. There take on the good old Cooper fabricated job.
Posted: Thu Oct 18, 2012 1:04 pm
by ace01
mk1 wrote:Personally I'd go for a maniflow 3 into 1. There take on the good old Cooper fabricated job.
+ one from me.
I've always tried to use the Maniflow Freeflow as it misses the couplings, which in my experience an LCB does not do. An RC 40 goes on well, is not too loud and looks right.
Posted: Thu Oct 18, 2012 1:20 pm
by Smiffy
The Maniflow Freeflow isn't a 3 into 1, it's a short LCB...............
Posted: Thu Oct 18, 2012 1:24 pm
I didn't mean the long 3 into 1, i'd never suggest one of those for a standard ish car. I meant this one.
http://www.maniflow.co.uk/index.php?vie ... oduct=1507
Posted: Thu Oct 18, 2012 1:37 pm
by Smiffy
Yep thats still a LCB, identified by the longer centre branch
Posted: Thu Oct 18, 2012 3:51 pm
by 814CWE
thanks for input
looks like the maniflow in the pics and an rc 40 then
will the rc40 go straight onto this manifold??
i take it it will mate with the std bmc inlet manifold as people say a lot of branch manifold flanges are fatter than the bmc twin carb standard inlet manifold
Posted: Thu Oct 18, 2012 4:07 pm
I'm not certain, but I suspect you will have to hack saw the first kink off the RC40 front pipe.
Posted: Thu Oct 18, 2012 4:11 pm
by 814CWE
deffo an easy fix then...
Posted: Sat Oct 20, 2012 10:11 am
by morris cooper
With the correct RC40 front pipe it's a straight fit to the Maniflow Cooper freeflow manifold, single box or twin box RC40,
Bill
Posted: Sat Oct 20, 2012 5:06 pm
by cheleker
As Bill says, fits straight on.
I prefer the twin box.
Posted: Sat Oct 20, 2012 7:25 pm
by Vegard
Single box RC40 is way too loud. Twin box is nice and subtle.
Posted: Sat Oct 20, 2012 8:35 pm
by Andrew1967
Guess it depends on your own preference.
I've got a single box RC40 on my 998 Cooper which is quite loud but sounds great. I tried a twin box RC40 on my 'S' but it was just too quiet. With a single box RC40 it sounds brilliant
My 998 has a Maniflow Cooper Freeflow which has good clearance on the drive coupling. The only problem I had was that the lower heat shield link plate that holds the throttle return springs fouled on the centre branch. I had to remove the link and relocate the return springs.
Posted: Mon Oct 22, 2012 3:44 pm
by cheleker
The "link" fouling problem is common with any of the "lcb" type center pipes; including, the Freeflow. It can be solved by spacing the link away from the two halves to which hit mounts using washers or nuts or short pieces of tubing.
Posted: Mon Oct 22, 2012 8:33 pm
by 814CWE
fab advice thanks
