help to identify this car
pawermini
Post by pawermini »
Hello, i need help whit this car:
Chassis vin no. A-A2S7L-33***
FE 496**
Regards
Pawermini
Nevsmini
Re: help to identify this car
Post by Nevsmini »
It's a LHD Austin mini 850. Dating from the FE number it would have been built around dec 62/Jan 63. Someone with info on the chassis number in the 33 thousands will give you a more accurate date. If you apply for a Heritage cert based on the chassis number you should get most info you require. Hope this is of some help.
pawermini
Post by pawermini »
Nevsmini wrote:It's a LHD Austin mini 850. Dating from the FE number it would have been built around dec 62/Jan 63. Someone with info on the chassis number in the 33 thousands will give you a more accurate date. If you apply for a Heritage cert based on the chassis number you should get most info you require. Hope this is of some help.
Thank you nevs, i was wondering the estimated build date, regards.
Simon776
Post by Simon776 »
FE 496**
The chassis number and FE Number look like they belong together but I think a build date of late May 1960 is much more likely.
Nevsmini
Post by Nevsmini »
Sorry pawermini I miss read I thought the FE number was 496 thousand instead of 49.6 thousand. Simon is right with the date! sorry for the confusion. :oops:
pawermini
Post by pawermini »
Nevsmini wrote:Sorry pawermini I miss read I thought the FE number was 496 thousand instead of 49.6 thousand. Simon is right with the date! sorry for the confusion. :oops:
its confirmed 30th may 1960 !!!
Simon776
Post by Simon776 »
Nevsmini
Post by Nevsmini »
Simon as my Dad says 'Years and Years of valuable experience' ;)
