Hi guy´s...
Can anyone help with the correct measures for drilling the holes for the early blower... as they need be there if it should be correct, with or without blower...
They are marked with a blue ring here...
Thanks in advance...
Holes on inner wing
Holes on inner wing
- Has thanked: 8 times
- Been thanked: 22 times
Re: Holes on inner wing
Hi René
This is the best available pic of the inner Wing of my november 62 Austin Cooper.
I have also the black blower mounted in the inner Wing. The Car on the photo is unwelded and original.
hope it helps
regards Fabian
hope it helps
regards Fabian
Hi..
Thanks for the reply...I need the correct measures for drilling the holes?? anuýone help with a draw with measures??
Regards René
Regards René
- IAIN
Specially for you ! The measurements are taken from a tape measure so are as close as I could get.
http://i50.tinypic.com/117bpqx.jpg
http://i47.tinypic.com/334nprl.jpg
IAIN wrote:Specially for you ! The measurements are taken from a tape measure so are as close as I could get.
IAIN....
You´re my man..
Best regards René
