Weber 45 dcoe...
tintoptom
Weber 45 dcoe...
Post by tintoptom »
Afternoon gents,
I'm hoping to get some info on the carb shown below. The numbers on it are as follows: (Type) 45DCOE13 and (No.) 2578. Just wondered if the '13' at the end of 45DCOE13 means anything... also, is it possible to date it from the No.? Any ideas anyone?
(...and if anyone's interested I'm looking to get rid of it and the 2 manifolds seen here. Will split if that helps!)
Cheers,
Tom
on swan neck:
spare Oselli inlet:
guru_1071
Re: Weber 45 dcoe...
Post by guru_1071 »
tom
the '13' indicates that its the correct model for use on a mini.
this indicates its a fairly early carb (pre 80's i think)
the later correct mini use webers are marked '152'
tintoptom
Post by tintoptom »
Thanks Rich! :)
I seem to remember that a chart or site link was posted on one of the earlier Mk1 Conversions forums regarding translating Weber numbers and corresponding applications. I'll have a look around and post a link if I find it...
..as it's a bit of a mysterious world to us Weber novices!!
Tom
coop12g295
Post by coop12g295 »
What price have you in mind for the dog leg manifold
251 ENG
Post by 251 ENG »
How much do you want for just the weber?
ivor badger
Post by ivor badger »
The 13 means the slow run drillings are for siamised inlet ports and was originally designed for an MGB. It then found its way onto a mini. The 9 was for a Healey 3000 with individual inlet tracts.
tintoptom
Post by tintoptom »
ivor badger wrote:The 13 means the slow run drillings are for siamised inlet ports and was originally designed for an MGB. It then found its way onto a mini. The 9 was for a Healey 3000 with individual inlet tracts.
Really interesting, thanks ivor.
coop12g295 and 251 ENG you have private messages (hopefully!)
Tom
littler
Post by littler »
thats a 40 with a 45 lid on it...
also the 13 originaly had a longer pump stroke and a strong pump spring too. but by now markings dont really mean out when it comes to settings as normaly they will have been of a few engines over the years.
guru_1071
Post by guru_1071 »
littler wrote:thats a 40 with a 45 lid on it...
so it is!
or a 'shuddersfield special' as they where known round here..... :lol:
Ronnie
Has thanked: 13 times
Been thanked: 33 times
Post by Ronnie »
Well spotted Adam. :D
Vegard
Post by Vegard »
So this 9 shouldn't be fitted to a Mini then? :)
http://cgi.ebay.co.uk/Weber-45-DCOE-Car ... 2a0a716f81
littler
Post by littler »
would be fine ;)
Vegard
Post by Vegard »
130 jets and 34mm chokes, sounds like 40DCOE territory doesn't it?
Le Coq Motorsport
Post by Le Coq Motorsport »
Nice to have a topic started on Webers.
What I need to know is...
What Webers to use o na crossflow head. (7 porter - 8 porter)
Type, size ( 40's- 45's), numbers, chokes, jets, etc...
Anyone had experience with Webers on crossflow heads ?
Cheers,
Dieter.
littler
Post by littler »
Vegard wrote:130 jets and 34mm chokes, sounds like 40DCOE territory doesn't it?
yer... bet what ever it was on wasnt much cop looking at that. probubly a fashion accesory :)
Vegard
Post by Vegard »
Le Coq Motorsport wrote:Nice to have a topic started on Webers.
Cheers,
Dieter.
http://www.atfreeforum.com/phpbb/viewto ... um=mk1mark
Tulka
Post by Tulka »
I got an inlet somewhere that i will put on Ebay someday.
Tulka
Tulka,
Is your manifold for 45 webers on a weslake head?
If it is, please contact me as soon as possible.
Tulka
Post by Tulka »
Found it after some searching.Big heap with parts,you know.
Tulka
In the shed
Post by In the shed »
I've seen the IDA(s) manifold....
The DCOE one looks awfully convoluted gas flow wise. The S that the charge has to undertake can't be good for performance.
