i need to find out if a late 60s early 70s landrover with an inertia seat belt set up would be the same fixings as a mini uses - bottom front fixing in sill, upper fixing at shoulder height , inertia reel in a vertical position
or
will landrover seatbelts fit a mini
chaars chaps
any one got a landrover ????
- pad4
- Frogeye61
Re: any one got a landrover ????
That sounds correct enough except that the LR mounts to the seat box on the inside (at the bottom of the seat cushion) and near the sill on the outside (20 cm down from the seat cushion)
I guess the best picture I have of that area is this one.
http://i183.photobucket.com/albums/x288 ... _1045c.jpg
