998 Cooper Engine+box into 1988 mini
Posted: Wed Aug 01, 2012 7:43 pm
Hi,
My mk1 racer style project consists of a bog standard 1988 mini 1000 and a 998 cooper engine and box. I know I am going to have some issues with the engfine conversion, so I wondered if anyone on here has ever put an early Aseries engine into a mini designed to have an A+?
Issues I can see and need advice on:
1) Gear lever linkage - i'm pretty certain the hole for the rod change mechanism won't be in the right place for the rod style mechanism - I believe i'll have to adapt the hole and weld on the bracket to accept the cotten reel linkage mount?
2) Drive shafts - the ones on the A+ are the pot type, but the cooper box has the cross type rubber mounts - what are my options with driveshafts and if I can get hold of the right driveshafts will the splines fit into the minis disc brake hubs? What else might I need for this?
3) Can I just strap the A+ alternator onto the cooper engine, and will the starter motor supply connections pop straight onto the cooper starter? Can I just delete the starter solenoid?
Any help on this would be great. I'm starting to think that buying a MK1 or MK2 project car may be easier, or even run the 1000cc A+ and transfer the cooper head and twin HS2's over...
