Mk 1 Indicator ends???
Posted: Fri Jul 27, 2012 11:09 am
by rolesyboy
Morning All. Does anybody know somebody who makes the black bakelite ends for Mk 1 indicator stalks. Mine just fell off in my hands
I am sure I recall somebody talking about this on a previous thread.
If not how hard would it be to make one up?? Prefer the originals and as I have about 6 with the same problem now might be the time to fix it. Cheers
Re: Mk 1 Indicator ends???
Posted: Mon Jul 30, 2012 8:05 am
by rolesyboy
Anybody????
Posted: Mon Jul 30, 2012 8:59 am
There was a guy in New Zealand who did a beautiful repair kit for these, but unfortunately I lost his contact details a while ago.
Posted: Mon Jul 30, 2012 9:21 pm
by 66S
I've never had his name but I think it included an LED bulb. I think he came from Kaiapoi (near Christchurch) and was into Morrie Minors. I'll see if I can find him.
Posted: Mon Jul 30, 2012 11:10 pm
by rolesyboy
Cheers Al/Mark. I had a nosey on the Trade me sight in New Zealand and it seems the guy has sold quite a few of these so I guess its a regular gig for him. I tried to join but you have to be resident in NZ to do so so couldn't contact him. If you have any joy let me know. Cheers. Mark
Posted: Mon Jul 30, 2012 11:42 pm
by 66S
Mark,
Can you PM me with the Trademe details and I will try to make contact with him.
Posted: Tue Jul 31, 2012 8:52 am
by Frogeye61
I moulded my own out of epoxy... guess it doesn't look too good though.
Posted: Tue Jul 31, 2012 10:31 am
by rolesyboy
I have a guy next door who is forever buggering about with small stuff for his model engines and parts for boats on a lathe. Would it be worth asking him to knock a few up? Not sure how easy it would be to get an appropriate bulb holder etc but if anybody has any pointers let me know and I will get on to it. Perhaps I could get an order on the go if anybody would like some. Cheers. Mark
Posted: Tue Jul 31, 2012 10:10 pm
by 66S
I have found an e-mail address (thanks KA2S4) and sent him an e-mail. I'll let you all know when I hear from him.
Posted: Tue Jul 31, 2012 10:44 pm
by 66S
I received the following reply.
I am receiving Ian’s emails while he is overseas, he will not be back in NZ until the middle of December.
Maybe we can make contact then if no other source is found.
Regards
Posted: Wed Aug 01, 2012 12:51 pm
by 814CWE
dunno why all the hard work..
the repro ones look ok and are perfectly fine in use
Posted: Wed Aug 01, 2012 8:57 pm
by 66S
Hard work, hahahahahaha, you're soft.
No problem to make a few calls to try to help fellow Mini owners.
Posted: Wed Aug 01, 2012 10:07 pm
by rolesyboy
"Prefer the originals and as I have about 6 with the same problem now might be the time to fix it. Cheers"
So 6 at say £35 a go =£210!
Thanks Al. Much appreciated.
Posted: Fri Aug 03, 2012 12:51 pm
by minitravellerman
Same happened to the one I fitted to the Mk1-esque Mini 1000. I have rewired the indicator lights to the works dash anyways but might get a repro one to help with the Mk1 look of the switchgear.
Posted: Sat Aug 04, 2012 11:24 am
by NZmember
How do you actually repair / remove the ends of the MK 1 indicator? I've got an indicator but it is missing the bulb holder and seemingly any wiring coming out of the end.
I just got a working one from Ebay but the original one is in better condition and I'd prefer to move the bulb holder over. But I don't want to end up destroying the bulb holder on the Ebay item in the process. Any hints and tips?
Posted: Sat Aug 04, 2012 1:38 pm
by Tim
You just wait and they fall off.
But seriously, I don't think you're meant to be able to get them off. I haven't examined an original one closely but they are either glued or molded on to the end of the chrome lever. The lever is knurled for the last cm or so to give it some key. You might be able to work one off, but I wouldn't guarantee that it won't break.
You might be able to replace the whole lever, but from memory the shaft that it is pivoted on is riveted over, so it wouldn't be straightforward.
Posted: Sat Aug 04, 2012 8:01 pm
by KA2S4
You can withdraw the metal bulb holder from the black plastic end piece, (is that what you meant?) just pull it out, may crack the plastic though. It should come out with the wires attached.
Don't forget to un solder the wires and feed them through gently.
J
Posted: Sun Aug 05, 2012 12:00 am
by NZmember
Sounds like I'll end up destroying it. Best leave the complete one alone as use as is.
Thanks for the feedback
