Hardy spicer couplings
Posted: Fri Jul 20, 2012 6:41 pm
by rolesyboy
Seen a set on e bay and wondered if the will be a direct swap for the rubber couplings/yokes I have on my car at the moment? 22g1128 Gearbox with remote housing. Do they just push on the diff splines and on regular driveshafts? Cheers.
Re: Hardy spicer couplings
Posted: Fri Jul 20, 2012 7:15 pm
by Smiffy
You need the rest of the parts as well as the coupling's, eg side covers and diff output shafts.
Posted: Fri Jul 20, 2012 9:08 pm
by rolesyboy
Ok, great, Anything else? Can I buy any old side covers and how do they differ?
Posted: Fri Jul 20, 2012 11:56 pm
by Lord Croker
The side covers for the Hardy Spicer shafts are of a larger bore size, so I'm afraid any old side cover won't do.
Posted: Sat Jul 21, 2012 7:00 am
by Vegard
I've got a set of Hardy Spicer couplings that fit standard diff covers. Home made?
Posted: Sat Jul 21, 2012 9:17 am
by 1071 S
Because I actually have English minis I'm not totally familiar with the Oz versions - But I believe we had two kinds of HS joints - that were indeed different. One kind for the S and the other for the Mini.matic..
Cheers, Ian
by guru_1071
Vegard wrote:I've got a set of Hardy Spicer couplings that fit standard diff covers. Home made?
jack knight
Posted: Sat Jul 21, 2012 9:19 am
by guru_1071
Lord Croker wrote:The side covers for the Hardy Spicer shafts are of a larger bore size, so I'm afraid any old side cover won't do.
you can use std side covers if your stuck, simply machine them out to accept the larger bush. the material is a little thin, so it doesnt offer as mush support to the bush as the proper 22g420's do, but it will work - people have been doing it for years.
Posted: Sat Jul 21, 2012 9:21 am
by guru_1071
1071 S wrote:Because I actually have English minis I'm not totally familiar with the Oz versions - But I believe we had two kinds of HS joints - that were indeed different. One kind for the S and the other for the Mini.matic..
Cheers, Ian
on autos, the hardy spicers are the same (and worth hunting down, as they never get the hammer the s ones do!), its the output shafts that differ. the oututs can be fitted to a normal pot joint diff to convert it to hardys. they make getting the engine out easy as you dont have to undo the philidas nuts, you just treat the hardy spicer and the output shaft as a 'pot joint' and knock it past the snap ring.
Posted: Sat Jul 21, 2012 11:16 am
by 1071bob
Posted: Sat Jul 21, 2012 11:19 am
by Dean
I bought a set of push on H S outputs from min-e-bitz, and then got a machine shop to lathe them down to fit standard output covers, but I made sure the bushes were in good condition and had the outputs matched to each cover with there right tolerances.
Posted: Sat Jul 21, 2012 11:46 am
by guru_1071
1071bob wrote:There are some hardy spicer output flanges around which fit the standard mini output shafts, identifiable by a chamfered edge and no internal groove for the split collets used on the 'S' and auto.
those are the auto ones, the later autos have a welch plug in the end and a groove machined inside for the snap ring on the pot joint output shaft (so they look just like a potjoint, but with a flange end rather then the cup for the balls)
i think (distant memory) that the first autos used the ones in your photo with the rubber coupling type arangement of holding them to the diff - these will not be any use for quick removal, but would be fine for a 'normal' car wanting to use hardy spicers.
ive never seen an auto that used the bolt & collet type fixing arangement that the proper s output flanges use.
the side covers from an auto are unique to the auto box and cannot be used on a manual, only the hardy spicer flanges outwards are any use/value
Posted: Tue Jul 24, 2012 10:01 pm
by Andrew1967
When I fitted a H/S set up on my S replica, I bought an automatic diff assembly which had output shafts/flanges with the split collars and bolt. If I remember correctly all I did was change the final drive assembly to the ratio I wanted (3.1:1). For the diff covers, I had some standard covers machined out to take the bigger bushes and have so far had no problems.
Previous to buying the auto diff, I bought an assembly that had had the diff welded for auto cross (?) racing. The h/s flanges had been machined down to fit into the standard covers.
