lucas oplus electronig ignition
pad4
Post by pad4 »
well well - found all this under the bonnet of my mk3 S
lucas opus ignition
any info anybody
pad
guru_1071
Re: lucas oplus electronig ignition
Post by guru_1071 »
wasnt that known as lucus 'hopeless' back in the day???
pad4
Post by pad4 »
worth taking it off i guess and replacing it with good old fastioned points
pad
You could always upgrade it!
http://www.reopus.co.uk/
pad4
Post by pad4 »
looks like it was made for 12 cylinder lumps so why would you have one on a mini
strange but its comin off
Ronnie
Has thanked: 13 times
Been thanked: 35 times
Post by Ronnie »
pad4 wrote:looks like it was made for 12 cylinder lumps so why would you have one on a mini
I purchased my Mk3 S in 1971 intending to use it in rally's I contacted Lucas in 1972 querying the use on the distributer of quickafit points, This is their reply
"We do not make a special quickafit contact set for use on vehicles that are being used on rallies. Tests on the one piece set have shown that it can be used for
rallying or racing up to 9000 rpm without problems being experienced, and all distributers now manufactured by ourselves for use on these vehicles are fitted
with the one piece contact set as standard. However, if you wish to exceed the 9000 rpm, may we suggest that you use an Opus ignition system, details of which
are given in the enclosed publication."
Let me know paul if you want what appears to be fitting instructions for Lucas 32DE4 Opus ignition system! ;)
