1071 Cooper S Camshaft
rolesyboy
Has thanked: 7 times
Post by rolesyboy »
Anybody give me a heads up on what cam is needed for a 1071 S engine please? What does it look like and how would it differ from say a 1275 S (if at all) Cheers. Mark
ivor badger
Re: 1071 Cooper S Camshaft
Post by ivor badger »
Same camshaft as 1275 until the 510.
rolesyboy
Post by rolesyboy »
Forgive me but what is the difference between a 510 and this one? I have been offered one stamped/Graded EN32. How much would something like this be worth? Cheers. Mark
Has thanked: 125 times
Been thanked: 34 times
An original will be Pin Drive, 1/2" Lobes and no rings or other ID on the shaft. The 510's where the same but had a single ring. Best to measure it or have it measured to be sure what you have and that it's not worn. The 'EN32' I am not familiar with as a cam grind per se, just wondering if it an Elgin from the states?
skorstensfejeren
Post by skorstensfejeren »
The original is using pin drive, as wrote on top... and number is AEG 148..
