Rear Subframe
Jamie
Rear Subframe
Post by Jamie »
building up my new rear subframe at the moment before i bolt on the shell....was wondering whether i should be putting some sort of padding between the frame and the shell? Not sure if there was some there in the first place or not?
is this worth doing?
thanks
Jamie
Mini4Ever
Re: Rear Subframe
Post by Mini4Ever »
Originally, there is some small padding. These however soak up all the water and easily help the rust bug...
Too many cars...
IAIN
Re: Rear Subframe
Post by IAIN »
They put a rubber pad in place of the felt on the later cars. It was glued to the subframe top web. ( where there is a triangular shaped pressing on the top of the web )
It is a good idea to have it because the subframe could touch and rub on the floor.
Smiffy
Re: Rear Subframe
Post by Smiffy »
If the subframe flexes that much, you need a new subby !
Re: Rear Subframe
I replace the original carpet underlay type pad with a new one that has been thoroughly soaked in waxoyl this seems to work fine & won't promote rust either.
Jamie
Re: Rear Subframe
Post by Jamie »
thanks for the advice guys, the waxoyl'd pad sounds the way to go.
thanks again
66S
Re: Rear Subframe
Post by 66S »
A waxed felt pad is exactly what I did when I had the S frame out during my recent change back to Hydro. I did the same on the front one too.
Amazing how great minds work alike !! ;)
Regards
Al
