Universal joint on mini steering column
pad4
Post by pad4 »
ok i spent 6 hours getting the seating right , machining steering wheel spacers but i need to movevthe wheel over to the left so im all inline, only way i can think of is using a uj between the rack and column
anyone done this on a rally / race car ??
pad
graham in aus
Re: Universal joint on mini steering column
Post by graham in aus »
Someone in the Se7ens or Migs will have done it, not sure about rally...
http://www.demon-tweeks.co.uk/Search.do ... rsal+joint
Chalkie
Post by Chalkie »
I'd leave it on a rally car
or you could find an austin allegro steering coloum few people fit them as i've been told can't be 100% though
guru_1071
Post by guru_1071 »
allegro, meastro etc have a uj & shaft, but you will need to have an extra support for the outer shaft
wil h has done this in his race car and its a weird feeling to get into a mini with a 'new' steering wheel angle!
Chalkie
Post by Chalkie »
guru_1071 wrote:allegro, meastro etc have a uj & shaft, but you will need to have an extra support for the outer shaft
haha at least someone knows :] i couldn't remember 100%
guru_1071
Post by guru_1071 »
here is a photo of how you can do it
(this is gergo from hungarys car - they guy who has the nice yellow early cox gtm)
GraemeC
Post by GraemeC »
I like that idea - might solve a problem of mine. Do you know if that a complete column from another BL offering or a grafting together of columns?
guru_1071
Post by guru_1071 »
GraemeC wrote:I like that idea - might solve a problem of mine. Do you know if that a complete column from another BL offering or a grafting together of columns?
graeme
you can use the lower part from an allegro - i sold an allegro column to someone years ago who did just that
will h used a maestro/montego column in his hill climber
pad4
Post by pad4 »
So could we not just weld a UJ to the bottom of the mini steering coloumn then ??
although thinking about it we would also need to support the bottom end of the column housing as shown in the pic
pad
Has thanked: 257 times
Been thanked: 224 times
The hillclimber Mini set up is pictured in link below, as said uses a Montego or Maestro column, splines are the same and it has 2 universal joints.
http://www.twin-turbo.co.uk/album/slides/IMG_0088.html
http://www.theminiforum.co.uk/forums/to ... ng-column/
999 ORX
Post by 999 ORX »
What a good idea, I've been looking at doing something similar but also incorporating/making it a quick rack. But It uses a standard steering rack! ;) and a inline gear reducer that reduces full turn to turn lock making it quicker to turn.
