rear side window rubbers
Posted: Wed May 09, 2012 10:23 pm
by captain
having a small prob with these rubbers i bought from m-machine, for a 1960 rear opening quarter window,rubber is far to tight,and not allowing the catch to shut,if you put them on (ARSE FOR ELBOW ) they are fine and window shuts and seals perfectly, but this leaves a rubber seal edge on the inside sticking out. any ideas ??? :!:
Re: rear side window rubbers
Posted: Wed May 09, 2012 10:34 pm
by Chalkie
I had this issue! I warmed the rubber with hot water and pushed the window in while a mate made sure it was all inside and then he shut it and we left it for over a month and it was fine after that :)
Posted: Wed May 09, 2012 11:09 pm
by captain
RidingLow wrote:I had this issue! I warmed the rubber with hot water and pushed the window in while a mate made sure it was all inside and then he shut it and we left it for over a month and it was fine after that :)
thanks will give it a try, but i think there is too much strain on the delicate catches at this point, dont want to break them? :D
Posted: Thu May 10, 2012 9:14 am
by NotNormal
Got exactly the same issue on one of my side windows, will give this hot water method a go also and see how it goes.
Posted: Thu May 10, 2012 11:33 am
by SteveG
same problem here with my minispares ones.. Will play with some hot water :)
Posted: Sun May 13, 2012 9:49 pm
by Chalkie
I also use a hair dryer to warm rubber up to fit front and rear wind screen fillers haha :)
