Cylinder head manufacturer
NZmember
Post by NZmember »
Nicely worked 12G202 head with 31/26.4mm valves. Painted a distinctive blue colour - does anyone have any ideas on the company who did the work?
Chalkie
Re: Cylinder head manufacturer
Post by Chalkie »
Has it been stamped near the themo stat housing or on a flat surface?
alot of companys stamp around them area's
Toby
Has thanked: 12 times
Post by Toby »
The valves fitted are just a size up from the originals 27 mm and 25.4 mm, the 12g202 head I have is blue as well. I believe the heads fitted to the later 1098s were quite frequently painted this colour.
T.
Pete
Has thanked: 52 times
Been thanked: 139 times
Post by Pete »
You'll find the same blue primer on many blocks and heads applied at the factory.
NZmember
Post by NZmember »
Thanks. Just to say there is precious little flat space around the thermostat housing for any stamp marks. I had not seen that blue colour before.
1071 S
Post by 1071 S »
Some people stamped them at the other end behind the heater tap.
Cheers, Ian
