Need your opinion on SPQR gear shift
Hello there,
For my next project I plane to use a SPQR gear shift. Before to modif the bodyshell I would like to be sure this item is also drivable than a remote change gear box or not ?
I want to fir one because I found this accessorie really beautifull without the plastic cover.
Thank you in advance for your help.
Re: Need your opinion on SPQR gear shift
If you have a wavy wand gearchange the SPQR is quite a good alternative, I had one in my 62 van and never had any trouble with it, I liked it.
Pete
Pete
nothing wrong with wand change,,
i had an spqr in one,and change is good but without the proper console for it,,neutral "gate" is a bit odd to say the least and the gear throws,although smooth are very very long
worth a try but the bodyshell has to be cut for fitment dont forget...
- Been thanked: 9 times
If the unit is in good condition without too much slop in the joints its pretty good, but as has already been said its probably no better than the standard magic wand in good condition.
An interesting period mod, but maybe not a sensible one, particularly when you have to cut 2 big holes in the floor.
Thank you for your feedback !
I plane to use a gearbox like this (Thanks ChrisB for the pics
) with a 1293 engine.
Like this if it doesn't work I could change with out too much modification on the gearbox.
I planned to put the SPQR in a project which was already modified a lotmk1 wrote: An interesting period mod, but maybe not a sensible one, particularly when you have to cut 2 big holes in the floor.
- Has thanked: 4 times
- Been thanked: 22 times
The SPQR won't fit a gearbox like that, that's a pudding stirrer remote box as used in commercials and Mokes. The SPQR will only fit the early 850 magic wand.
You'd get a far superior gear change by fitting the correct gearchange extension and making it into a proper remote.
Tim
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
1955 BSA C11G
1969 Triumph TR6R
That's actually the magic wand fitted to late 4 synchro boxes as fitted to 850's as well as commercials etc. The wand itself is different from the early one as it has the groove on top instead of in the side. That setup is quite good and of course you can fit a big engine without problems because the box is 4 syn. The main problem being that you don't get the extra stability provided by a remote so the engine will probably go through steady bar bushes unless you fit some kind of ultimate steady.
Thank you for yours answers, I take some pics of my SPQR and it have two slot on the ball... one in the same place as two magic wnad I have and an other.... is it the slot needed to be fited in the gearbox ???
An other question ?
Does anyone have the fitting instruction for the SPQR gearshift ?
- Tedwong
Hi there,
The following Japanese blog I've came across may help.
It got 3 pages all about SPQR products, and showed how the 850 floor is cut to fit the gearchange.
The 3rd page also talk about the engine stabilizer which Rolesyboy interested in.
As for translation, may need help from our Japanese members here.
I also have a set of this gearchange plus console, but always hold back from fitting it by cut the floor!
Enjoy:
http://blogs.yahoo.co.jp/type_8am/folde ... l?m=lc&p=1
Ted
Enjoy:
Ted
Thank you so much for yours answers, I now have all the necessary parts to fit the gear shift.
I let you know asap
I let you know asap
