Mk3 S
Mk3 S
My mk1 hasn't made much progress this year as my garage is rammed full of work stuff. I had a day off recently and managed a day stripping another of my 'projects', a 71 blaze S.
Looks pretty solid
'til you get inside!
Boot nearly as bad
'Works' method of removing the sub frames
Plan is to add some strengthening, then get most of the rot cut out. When time and funds allow i'll get two half floors in.
Looks pretty solid
Boot nearly as bad
Re: Mk3 S
Aye, there's a bit of rot on the leading edge of the crossmember on the drivers side, but it should be an easy repair when the floors are cut out. Above the floor its very solid, other than one rear arch and next to the accelerator pedal. Even the front end is fine, though I might need a new slam panel after we caught the engine on it lifting it out with the fork lift.
Re: Mk3 S
Just a bit! Hopefully i'll get a day a week on my cars now that work is quietening down. My 1071 is painted and rolling but still needs lots of work, the mk3 here needs plenty and I have a pick-up just as bad.
I have three young sons and the cars will eventually be theirs, good job I have nearly ten years to get them finished!
- medwaybeat
Re: Mk3 S
Nice project. I have a mk3 1000 (built in 70 and registered early 71) in a very similar state to your S. I’m a bit clueless as how to attack it, so any pics of work in progress would be a lot of help. And it was supposed to be finished for when the kids turned 17, they are 20 and 21 now.
Re: Mk3 S
Hi
Great find and good luck with the restoration. Nice to see that all the boot board brackets are still in place, and the roof also looks nice.
Best Regards Kristian
MGB Roadster 1963
Morris Mini Cooper S Replica 1967
Morris Mini 1000 mk 2 automatic 1968
Morris Mini Clubman 1275 GT 1971
Austin Mini Clubman 1275 GT 1973 7 port head
MG Midget 1275 1970
MG Midget 1275 1970
