Re: Polishing Scratched plastic
Posted: Wed Feb 01, 2012 8:57 pm
by wantafaster1
Really good idea, have to try it. Can I suggest caravan window cleaner as well? Designed for clear perspex, or whatever the window is made from so it can't be that aggressive.
Posted: Wed Feb 27, 2013 8:21 pm
by java gt
I found that on rear lenses that had cracks on them that a couple of light coats of clear rattle can laquer works wonders on consealing cracks.
Posted: Thu Feb 28, 2013 8:24 pm
by pad4
Vuplex - one of the best plastic/polycarbonate polishes on the market
Posted: Tue Mar 26, 2013 1:19 pm
by georgek
I've had good results with Brasso to polish-up dull paint work and lenses try it on a small area first, wax over to seal when finished.
Posted: Tue Mar 26, 2013 7:02 pm
by 66S
Using Brasso has been around for years but I usually start with wet and dry sandpaper(400, then 600 and finer if necessary), then rubbing compound and finish with Brasso.
Al Brass (often known as Brasso !!)
