Ball joints and nuts and bolts for a potential show car
Posted: Tue Dec 27, 2011 5:23 pm
by rolesyboy
Some of the cars on here look really impressive show winning cars and so I wondered what you guys use top stop your nuts from going rusty..... An example os the nuts and bolts etc on the front ball joints. Having done several thousand miles mine look distinctly rusty and short of washing and drying them off every time I use the car I wondered what finish other people on the forum use to keep their nuts looking good
Stainless, plating, paint...? Cheers. Mark
Re: Ball joints and nuts and bolts for a potential show car
Posted: Tue Dec 27, 2011 5:33 pm
by InimiaD
Good question. I have the Same problem here with quickly rusting ball joints etc.
I intended using a clear spray laquer on the offending nuts etc when I start putting the Woody back together.
Any other suggestions as to how you learned folk would tackle the issue..?
Posted: Tue Dec 27, 2011 5:49 pm
by STG95F
Hi , I had all my Ball joints plated before fitting !! on my show car (STG 95F) Mini Cooper mk2
Hope this helps Ian
Posted: Tue Dec 27, 2011 5:54 pm
by rolesyboy
Great. Which bits can be plated? What plating did you use? I was unsure with this as I thought it may interfere with shimming etc. Are you pleased with the results? Are you able to use the car without fear...
Cheers. Mark
Posted: Tue Dec 27, 2011 6:16 pm
by Dean
I have Stainless steal bolts from smithy bits.
Just caution on S/S spring washers on suspension parts. Best to use high tensal
Posted: Tue Dec 27, 2011 6:27 pm
by STG95F
I had mine brite Nickel plated , and looks very good and has lasted upto now , but it is a show car
Posted: Tue Dec 27, 2011 8:47 pm
by 814CWE
clear lacquer works ok,if u not using stainless
just remember to re touch up when it is undone for remedial work
Posted: Tue Dec 27, 2011 8:56 pm
by swifty
Same as dean , ive used all stainless. works out quite expensive though
Posted: Wed Dec 28, 2011 10:41 pm
by ivor badger
swifty wrote:Same as dean , ive used all stainless. works out quite expensive though
Especially as the bi-metallic corrosion can reach a potential 1.2v and it's the ordinary steel that disappears.
Posted: Wed Dec 28, 2011 11:06 pm
by rolesyboy
Eh?????
Posted: Thu Dec 29, 2011 12:47 pm
by 814CWE
yer,,,,eh????
