Radius Arm Bush Removal
Posted: Tue Dec 27, 2011 2:44 pm
by WNX700H
I have a tool which removes the needle rollers but this is not long enough to remove the phosphor bronze bush in the outer end. Any tips on how to remove this one please , I have the reamer to ream the new bush.
Re: Radius Arm Bush Removal
Posted: Tue Dec 27, 2011 8:49 pm
by 814CWE
weld two slim punches together,,insert and ..whack!
well it worked for me
shame i dont have the reamers
Posted: Tue Dec 27, 2011 9:01 pm
by JanWulf
Or take a smal saw blade and cut it
Also sliding hammer & pull-thingy (dont know the word, this:
http://www.v-tools.ch/osc/images/1.30%2 ... zieher.jpg ) work well
Posted: Wed Dec 28, 2011 8:50 am
by guru_1071
ive got the two churchill pullers which make light work of drawing the bearing and the bush out, those and the proper reamer make doing radius arms almost a pleasure!
in the past i have used a long screwdriver to 'bash' them out
you can also use a normal slide hammer kit with an expanding head
Posted: Wed Dec 28, 2011 1:26 pm
by Andrew1967
The bronze bush is split. Using a small cold chisel you can bend the bush inwards (the more worn it is the easier it is) and this will loosen it in the arm. Use a pair of side cutters or long nose pliers to pull it out. Alternatively a long drift from the other end will push it out.
Just done this on my pick up radius arms. Took less than 10 minutes each side to get the bush out.
Also got to put my autojumble bargain £12 Churchill reamer to good use
Posted: Wed Dec 28, 2011 2:47 pm
by guru_1071
£12, now that WAS a bargain.
a little tip for these, if its blunt they can be sharpened, i didnt believe mark that they could, he did mine, and its like a new tool
Posted: Wed Dec 28, 2011 5:45 pm
by InimiaD
Oooo, pray tell. I reckon mine needs a bit of sharpening.
Posted: Thu Dec 29, 2011 12:50 pm
by 814CWE
nah then....
#early radius arms which fitted to 59-61 types
can you use the standard spindle that comes in repair kits,,but use two bronze bushes rather than a bush and a needle roller??
or just get the arm to an engineer and get the later kit fitted with needle rollers?
my left radius arm on my 59 is gettin well grim!!
Posted: Fri Dec 30, 2011 8:32 am
by 970s
Sorry!
If no reamer is available, any alternative? like the small honing stone as we use in the bore,?
Had try on the diff housing bronze bush and it works out fine!
AL
