My gearbox needs a dentist
Posted: Sat Dec 24, 2011 2:33 pm
by Vegard
I've just stripped my SC gearbox, literally, and found this:
The car drove perfectly well, this is from the last outing:
http://www.youtube.com/watch?v=m34IS15X09U
Obviously, there's something wrong with third gear here. I'm wondering if this happened while opening the two big nuts while dismantling. Could it be? The third gear has also got a mark on one tooth.
Re: My gearbox needs a dentist
Posted: Sat Dec 24, 2011 6:32 pm
by guru_1071
Vegard wrote: Obviously, there's something wrong with third gear here. I'm wondering if this happened while opening the two big nuts while dismantling. Could it be? The third gear has also got a mark on one tooth.
verg
thats your own fault
boxes should always be locked in 1st and 4th when your undoing or doing the large nuts up.
locking them in 1st and 3rd often breaks teeth off due to the loading on the gears.
silly boy :x
Posted: Sun Dec 25, 2011 8:38 am
by Vegard
I was thinking that. Now send me some spares :-)
Posted: Mon Dec 26, 2011 1:28 pm
by 36inter
I've done that and took a couple of teeth off, when you thinks of how much power and strain you put on a gearbox when driving it hard its difficult to imagine that doing a nut up would strip teeth, thanks for that info Guru I had'nt appreciated there would be a difference with which gear was locked, learn something new every day.
Pete
Posted: Wed Jan 04, 2012 8:58 am
by Vegard
Donations for this expensive lesson could be sent to Rich. As he's getting all my money anyway ;)
Posted: Wed Jan 04, 2012 10:40 am
by guru_1071
Vegard wrote:Donations for this expensive lesson could be sent to Rich. As he's getting all my money anyway ;)
thats a good idea, i could do with some cash, :lol: :lol:
Posted: Fri Jan 06, 2012 1:53 pm
by minicentie
Did you loosen the pinion and input gear with a air assisted tool?
Always use normal force,never airtools on a gearbox,is my opinion.
Used to work for tools departemnt of Atlas Copco;very expensive airtools !Often used in car factories because of it's reliable use .
Posted: Sat Jan 07, 2012 4:36 am
by 970s
:oops: ;) :oops:
No No No!
No impact gun, air tools on gear box or engine parts, unless you are workin gin a scrape yard!
We have learnt too much expensive lessons!
And Mini parts are so fragile - I mean tiny in dimensions! :mrgreen:
Posted: Sat Jan 07, 2012 4:37 pm
by Vegard
Nope, no air tools. Just a 20" lever, big viking muscles and loc-tite on the nuts.
Posted: Sun Jan 08, 2012 11:20 am
by Tim
Vegard wrote:... loc-tite on the nuts.
Doesn't that sting?
