Front Brake Hose Fitting Clips
Posted: Mon Dec 19, 2011 3:51 am
by 970s
:idea: :?:
Help! When fitting the front brake cross over hose, there is 2 clips to locate the line, should it be fitted under the subframe rearward edge or the line on top of the subframe beam?
I found there is various types of fitting methods!
Single line/ dual line circuits! :?:
AL
Re: Front Brake Hose Fitting Clips
Posted: Mon Dec 19, 2011 7:47 am
by andy1071
The single line systems have the pipe clipped under the top section of the subframe.
-So it's nicely protected.
Posted: Mon Dec 19, 2011 7:45 pm
by ricardo
Check here mine: viewtopic.php?f=6&t=335&start=20
I did it as I found it, I believe it is the correct way.
