3 Synchro Gearbox Builds Blyton
Posted: Sun Mar 09, 2025 7:54 pm
I have 3 x 3 Synchro gearboxes to build, floating here to see if there is any interest so I can bring along to Blyton:
22G68 wand
22A1288 Mini remote
22A1522 Mini remote(n.o.s casing)
New bearings, shaft, baulk rings and centre pick up.
Can be built with rubber joint, pot joint or HS diff outputs.Standard diff or x-pin
standard ratio B-Type helical gears or new close ratio straight cut gears.
Final drive of choice from 2.7 to 4.1
Any interest, message me with your spec and I will add a price to the advert.
Regards Jason
22G68 wand
22A1288 Mini remote
Regards Jason
