what air filter box is this ?
Polarsilver
Has thanked: 29 times
Been thanked: 44 times
Post by Polarsilver »
Could not help a Forum Member looking for a 1071 Airbox .so now asking your advice to identify what is this Airbox seen in the photo part number.?..looking on Somerford they list ..
12A675 Air Filter Assembly= 1963-69 not PCV Valve.. Or is it 12A955 Air filter Assembly = 1964-69 model with PCV Valve ?
the difference between the two air boxes is the " position" of that small breather pipe that takes the hose from the rocker cover.
Also wanted the small in length bell end extension tube that fits into the intake pipe part number 12A675 that is secured by that band clamp ..if any about ?
Has thanked: 94 times
Been thanked: 77 times
Re: what air filter box is this ?
Not the 69 model. No PCV take-off on mine when new or my current one
timmy201
Been thanked: 25 times
Post by timmy201 »
The PCV Cooper S didn’t have a hose from the rocker to the air filter box (as this would have upset the PCV). They just left that small pipe on the filter box open
Example from the Australian brochure
https://www.ausmini.com/forums/viewtopi ... lit=Cooper
Hipwell
Post by Hipwell »
You sure the end tube isn’t in there. Looks like you can see the radius of it in the photo? They do get rammed in.
1071bob
Been thanked: 40 times
Post by 1071bob »
The airbox in your picture is the later type. The early ones had the angled pipe take off to line up with the S type rocker cover vent.
Other differences are the two ' X dimples' in the base to give more clearance to the SU dashpots which bent the lower face on the early ones.
The other modification was to shorten the two pressing at the rear, I think this was done to make it easier to manoeuvre the housing in between the
scuttle panel and the wingnut studs on the taller 1275 motor. They moved the defunct metal pipe to the left to clear the PCV valve so it could still be used on the early cars. The lids are the same on both types.
Has thanked: 16 times
Been thanked: 46 times
Was going to jump in on this but as usual Bob has covered the differences in some detail. From above is only the pipe position that is different, so I supposed a modification would be possible. The very first 970s and 1275s also had this filter I believe, but only for a month or so.
Isn't it amazing just what info there is available from forumers on this site. We're all very lucky I say!
Polarsilver
i learn something new everyday .. thanks to all. but question now is what is the part number 8-)
Also Wanted is the "Tube" air insert with bell end that the band clamp secures ( as seen in Bobs photo;)
Somerford show that part to be 17H8382
1071bob
Post by 1071bob »
I agree with Matt, looks like the intake extension is still in the tube but pushed in to its shortest length. If it was missing the end of the tube would show the 'slots' in the outer. The extension piece is 17H 8382.
Polarsilver
Thanks Bob.. taking your advice & looking at the Extension Intake Tube yes it is pushed fully in .. :oops:
Toby
Has thanked: 9 times
Post by Toby »
Polarsilver wrote: Tue Feb 11, 2025 10:11 pm Now asking your advice to identify what is this Airbox seen in the photo part number?
To put a a date to it, this is the model that was used on MK1 S models post June 64
