Dismantling chrome window latches
MagicWandWoody
Has thanked: 17 times
Post by MagicWandWoody »
Just acquired some chrome window latches which make up a partial set (plus a duplicate, as the pic shows).
Dismantling the one on the right for cleaning is easy.
The one on the left, though... how's that taken apart? Or isn't it?
Has thanked: 94 times
Been thanked: 77 times
Re: Dismantling chrome window latches
Too greasy to see clearly but it LOOKS as though it's rivetted together
steve1071
Has thanked: 10 times
Been thanked: 14 times
Post by steve1071 »
The metal surrounding the washer that the pin passes through is peened over to hold it in place. Knock it back, hold the catch carefully in a vice and whilst pushing the button in get a small screwdriver to lever out the little washer. Watch for the springs flying around though….
timmy201
Been thanked: 25 times
Post by timmy201 »
The pin on the left one looks like it’s worn/broken and may not have enough length left to lock well
I use a similar method to Steve - hold the button closed with a cable tie or in the vice, remove the peened edges and then you can get a pick or small screwdriver through the washer and lever it out
If you don’t need to disassemble it to replace a part, you can also soak it in a tub of degreaser (or your favourite alternative) and then cycle the button to clean it out. You can spray in some grease once it’s clean and dry
