Cooper S mk3 solenoid position
Metronick
Post by Metronick »
Can anyone tell me the correct position for the starter solenoid on a mk3 Cooper S?
Nick
Ronnie
Has thanked: 7 times
Been thanked: 19 times
Re: Cooper S mk3 solenoid position
Post by Ronnie »
O/S inner wing/valance and if you are into detail they came with the red push button lucas solenoid. ;)
Metronick
Post by Metronick »
Thanks Ronnie.
Do you have a photo of one fitted ?
Nick
Ronnie
Post by Ronnie »
No sorry I don't, :( its under the servo, if its a restoration the screw holes may be in your panel, it's possibly in the same position as a standard car I would think.
Metronick
Post by Metronick »
Ronnie wrote: Fri Jan 31, 2025 11:25 am
Thanks Ronnie
Metronick
Post by Metronick »
Anyone else have a photo of one in situ ?
Nick
InnoCooperExport
Post by InnoCooperExport »
The one on my Inno 1300 Cooper (which is sort of a Mk3 S) has it on the clutch housing. You can see it in my build thread
Metronick
Post by Metronick »
Anyone with a photo from an up and running car ?
Nick
Metronick
Post by Metronick »
InnoCooperExport wrote: Mon Feb 03, 2025 11:10 am The one on my Inno 1300 Cooper (which is sort of a Mk3 S) has it on the clutch housing. You can see it in my build thread
Ronnie
Post by Ronnie »
But the Mk3 S is on the inner wing :?: :shock: I would think that the position will not be changed from the basic mini on the production lines as the cable runs would be identical :!: The mk3 S was just a mini with mechanical upgrades the trim was just standard unlike the Mk1 & Mk 2 S models.
Ronnie
Post by Ronnie »
Ronnie wrote: Tue Feb 04, 2025 10:57 am But the Mk3 S is on the inner wing :?: :shock: I would think that the position will not be changed from the basic mini on the production lines as the cable runs would be identical :!: The mk3 S was just a mini with mechanical upgrades the trim was just standard unlike the Mk1 & Mk 2 S models.
Picture taken today car owned from new & that is where the factory fitted them the same as the 1000 & 850. :shock:
Metronick
Post by Metronick »
Thanks Ronnie, perfect, just what I wanted to see.
