speedo bulbs
panda911
speedo bulbs
Post by panda911 »
Hello.
I am having a problem with the bulb holders for main beam, gen light etc coming loose/dropping off the back of the speedo.
Is there a recognised replacement that anyone would care to recommend.
They are simply too old.
Thank you
BR
Paul
Re: speedo bulbs
Post by Old English White »
I've never known them get "too old". I have a couple of 1950s cars with those bulb holders and they've never given any problem at all. The ones I have had trouble with have always been new ones fitted to a replacement loom :roll: If that is the case with your car I wouldn't be surprised at all.
Best to get some original ones in that case.
Has thanked: 59 times
Been thanked: 54 times
Re: speedo bulbs
Can't you just bend the springs that run around the outer circumference a bit to ensure that they grip the rear socket part of the instrument.
hanlminiman
Has thanked: 12 times
Been thanked: 24 times
Re: speedo bulbs
Post by hanlminiman »
Sounds like a plan Peter especially as "Bend It" was I think a 1966 song after the Monte lighting fiasco. Wasn't there a slogan that Minis rule the bends back when I was a lad.
Re: speedo bulbs
Yes, but do you remember who sang Bend it, Bend it.......? Was it Dave Dee and the Bostons or as they were later to become.....?
hanlminiman
Re: speedo bulbs
Not Captain Beeky :lol: or as I am Titch.
maxidave
Re: speedo bulbs
Post by maxidave »
Dave Dee,Dozy,Beaky,Mick and Tich.One of the most succesful bands of the 60's.They purchased cars from Wessex Motors New Street Salisbury
(later Henlys) My early working days.Dave Dee bought a Silver Cloud 3,Tich a DB4. When Dave Dee arrived to view the Rolls Frank Moules the RR
salesman had no idea who he was and thought there was no way this scruffy guy could afford one.None of them bought a mini .Only Beaky is
still with us from the original band.Great guys.
panda911
Re: speedo bulbs
Post by panda911 »
Thank you all for your creative responses.
The sping clip comes out of the plastic backing. and leaves itself in the back of the speedo.
I will talk to Nick Rogers.
Thank you
BR
Paul
woodypup59
Been thanked: 20 times
Re: speedo bulbs
Post by woodypup59 »
I find the plastic bulb holders on new wiring looms can be a poor fit in original speedos.
Ive been known to cut them off and solder the original metal bulb holders onto the new loom.
woodypup59
Re: speedo bulbs
panda911
Re: speedo bulbs
Post by panda911 »
Hi Again.
I have just seen the Wood and Picket ad for a speedo wiring loom and wonder whether it would make my jobeasier if I
used the mate-n-lock connector type approach.
I have used the thinking for the removal the original benelite grill from the car when working in that area.
Thanks for your idaes, the claw retaining clip stuck in the back of the speedo and then upon removal fled towards the subframe at the back of the
engine never to be seen again.
