Purolator Spin On Oil Filter Head
Posted: Thu Jan 09, 2025 9:03 pm
by sugarhiccup
Hi all,
Looking for a ‘Purolator’ type spin on oil filter head that has the full-sized mating face to the block. I believe these may have been used on Sprite/Midgets at some stage?
Picture for reference:
Postage to Australia or U.K. can be achieved.
Many thanks! :)
Re: Purolator Spin On Oil Filter Head
Posted: Fri Jan 10, 2025 2:01 pm
by CooperTune
You do realize there are two versions. One places the filter further away from the block and transmission. I haven't jigged up one with sub frame in years. I believe there was a sub frame clearance issue with the longer one. I do like the short ones as they have the larger mounting area and threaded steel insert. Steve (CTR)
Posted: Fri Jan 10, 2025 5:57 pm
by sugarhiccup
CooperTune wrote: Fri Jan 10, 2025 2:01 pm You do realize there are two versions. One places the filter further away from the block and transmission. I haven't jigged up one with sub frame in years. I believe there was a sub frame clearance issue with the longer one. I do like the short ones as they have the larger mounting area and threaded steel insert. Steve (CTR)
Hi Steve,
Thank you, yes I had read this in another forum thread at some stage. I appreciate you bringing this to my attention again.
I would be looking for the compatible, shorter filter head option that doesn’t have clearance issues.
Cheers :)
